5400 miles & using oil
Old Feb 13, 2002 | 05:09 AM
zombiedude's Avatar
Default 5400 miles & using oil
My bone stock motor is using 1 qt. ever 1500 mile. this is not good. rings or PCV valve? any TSB's on this? 02 SS. Other wise this car is ok, cept for the 'ting' I here on left rear on shifting. Thanks to all. <img src="images/icons/confused.gif" border="0">
[ February 13, 2002: Message edited by: zombiedude ]</p>
Old Feb 13, 2002 | 09:32 AM
Bobby C 01TA's Avatar
Default Re: 5400 miles & using oil
hey man i had the same prob.. i switched from a 5-30 synthetic to a 10-30 synthetic.. ever since i got headers, the car runs more rich so it consumed about a quart and a half in only 1000 miles.. use 6 qts also.. oil consumption is a known problem with our cars.. just go to a heavier weight and add 6 qts and see how that does
Old Feb 13, 2002 | 07:59 PM
chads35thle's Avatar
What brand of oil are you using? Are you using a synthetic oil? Alot of revs over 3000 rpm(engine braking)?
Old Feb 13, 2002 | 08:34 PM
zombiedude's Avatar
5w-30 Molbil 1. Not many above 3000. but I do nail it sometimes. No engine braking, just throws in nuetrel when stoping. Went to AZ. From LA. after 300mile put-put driving then put 3800 mile on the interstate and did use some but it seems to be getting worst.
[ February 14, 2002: Message edited by: zombiedude ]</p>
Old Feb 14, 2002 | 07:45 PM
zombiedude's Avatar
Any more help? I need it. <img src="gr_sad.gif" border="0">
