Oil pump?
Old Feb 15, 2002 | 04:30 PM
smokin' joe 00 ss's Avatar
Default Oil pump?
Does anyone know the difference between the LS6 and 2001 oil pumps I see they are different part #'s and as long as I'm doing a cam change I'm going to replace the oil pump while it's tore down.
Thanks
Old Feb 15, 2002 | 06:07 PM
jmX's Avatar
jmX
Default Re: Oil pump?
The ported ARE pump I got was off a 2001 LS6 supposedly and it looked 100% identical to the 2000 LS1 pump (except for the porting ARE did of course). If you get a ported one, I dont think you can go wrong....
Old Feb 15, 2002 | 06:36 PM
Thanks, thats what I figured I can get a ls6 oil pump out of the warehouse for $52 so I thought I might get one and debur and polish it myself hell I use to do that to all the small and big block oil pumps I put in all my other motors. If I knew the thickness of a shim to put under the spring I'd do that too.
