SAE dyno correction factors and the LS1
I recall that over the years, my cars have behaved differently in the cold or in tyhe very hot. Some cars are far more down on power in the hot, and animals in the cold. Others seem good in either climate, adn seem less effected.
The SAE correction is obviously based on the amount of oxygen available for cumbustion in a given volume of air if you have the temerature, humidity, and barometric pressure.
Is it possible that the LS1 motor is just better at accessing oxygen and creating its own density than previous engines? Is it possible that the SAE correction factor is not totally accurate for our engines?
Back in Texas, I recall alot of the dyno folks mentioning that while LT1s dyno'd much worse in the heat, LS1s couldnt seem to care less. Yet the SAE correction factors treat them as the same.
We get a nice big waft of dry cold air through the US, and all of a sudden several vendors start showing off some incredible numbers. Without the benefit of any kind of obvious paradigm shift or revolutionary technology.
hrmmmm......
Thoughts?
\chris
As far as correction factors are concerned, I think this debate will continue on for years. Some people are happy with dyno results corrected to SAE standards and others are track performance oriented.
Todd
Dynos are 100% tuning tools, as Terry stated. People get SO wrapped up in peak dyno #'s, and it's getting really old. We have all of these magical #'s floating around without any track times. While it doesn't apply for ALL of them, many of the cars are running what I would consider big cams for stock cubes. I've seen more than one graph that would require shift points of 7,000 RPM with stock heads! It's all top-end power, and you'd better have a car setup right to get it to work its best (steep gears, FAT stall if an A4, etc.). There are many ways to eek more power out on a dyno as well, so the #'s don't mean much without track times for me.
I tested two of our shop cars just to see if there was a difference. What caught my eye was an unexplainable loss of power on my car. So then I tested another car that had no changes.
The test temps were 15deg hotter, so the Correction was higher, but even with that bother cars were down on power. I think they both lost 5-8 RWHP.
There may be many reasons for this, but one thing a correction factor can't account for is how the engine runs with the colder air and denser air.
So who knows, it kinda works the same way at the track too. A car will run a lot better when the air is cold, pressure high and humidity low. My guess better than what a car would run corrected in hot muggy weather.
Todd
