LT1 vs LS1, what are the actual differences?
Old Feb 20, 2002 | 02:05 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default LT1 vs LS1, what are the actual differences?
I'll list off the differences I know, please add to the list...
LT1
4.000 bore
3.48 stroke
Iron block
Reverse cooled
Traditional SBC firing order?
Cast aluminum intake
LS1
3.900 bore
3.75 stroke
Aluminum block
Different firing order
15 degree heads?
Composite intake
Old Feb 20, 2002 | 02:11 PM
Patman's Avatar
Default Re: LT1 vs LS1, what are the actual differences?
LT1=slow
LS1=fast
Sorry, I just had to say it! <img src="gr_grin.gif" border="0">
But seriously, don't forget that the LT1 has the optispark ignition system, while the Ls1 has the much superior single coil per cylinder setup.
Old Feb 20, 2002 | 02:12 PM
Hydra's Avatar
Stroke on the LS1 is actually 3.62" (92mm) and not 3.75"
You've listed the major differences between the two, here's what I have to add:
1.7 rocker arm ratio on the LS1 as opposed to 1.5 on the LT1
roller rockers on the LS1 vs stamped rockers on the LT1
hollow camshaft on the LS1
6.098" rods on the LS1 vs. 5.7" rods on the LT1
bigger main journal bearings on the LS1 (2.65"ish vs. 2.45" on the LT1)
and this is pretty significant... 4 head bolts/cyl vs. 5 head bolts/cyl for the LT1 and classic SBC
Also, LS1 has 6 bolt mains vs. 4 or 2 for the LT1
That's all I've got off the top of my head, I'm sure you guys can finish the rest...
[ February 20, 2002: Message edited by: Hydra ]</p>
Old Feb 20, 2002 | 02:20 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
ha! this could go on forever!
LS1:
*6-bolt main bearing caps
*cracked-PM rods
*one coil per cylinder
*factory roller rockers w/ 1.7:1 ratio (vs. stamped steel 1.5's for the LT1)
*larger fuel injectors
*deeper oil pan
*completely different head port design
*deep skirt block
*enclosed lifters
*separate valley cover
*CPS reluctor wheel
*negative deck height
*crankshaft is shorter than the LT1's
*6.1" rods vs. the LT1/4's 5.7" rods
There's a start. <img src="gr_stretch.gif" border="0">
__________________
Old Feb 20, 2002 | 02:50 PM
Damian's Avatar
LSX Mechanic
[quote]LT1=slow
LS1=fast<hr></blockquote>
I bet Jordon Munsser and a few other 9-10 second LT1 guys would beg to differ with that statement <img src="gr_images/icons/wink.gif" border="0"> .
Everything that's been listed is all I can think of at the moment...
Old Feb 20, 2002 | 04:06 PM
ChrisB's Avatar
How about you list what is the same
lifters
Chris
Old Feb 20, 2002 | 04:08 PM
LS1Tech Co-Founder
How about the physical dimensions of the blocks?
[ February 20, 2002: Message edited by: Pro Stock John ]</p>
Old Feb 20, 2002 | 04:16 PM
[quote]Originally posted by ChrisB:
<strong>How about you list what is the same
lifters
Chris</strong><hr></blockquote>
LMAO! I vote for that, too. The list is much shorter. <img src="gr_stretch.gif" border="0"> They're both OHV pushrod design. And there you have it!
__________________
Old Feb 20, 2002 | 05:49 PM
Patman's Avatar
Does anyone have a listing as to the weight difference between the two long blocks?
Old Feb 20, 2002 | 06:05 PM
Visceral's Avatar
What several engineers thought was a real paradigm shift from SBC-2 to SBC-3 was the bore spacing. For the first time ever, it isnt the standard 4.5 (???) inches of the Gen 2 small block. I dont recall what the LS1 bore spacing is. The coil-per-cyl is new for the SBC. Im thinking technology more than parts.
\chris
Old Feb 20, 2002 | 06:09 PM
XLR8NSS's Avatar
Adkoonerstrator
DOH!!
I thought the bore spacing was one of the only things they did carry over from a traditional small block. <img src="images/icons/confused.gif" border="0">
Old Feb 20, 2002 | 06:13 PM
Bad Habit Bird's Avatar
Gen II block 160 lbs LS1 block 107 lbs <img src="gr_grin.gif" border="0">
Old Feb 20, 2002 | 06:15 PM
lifters
Rod bearings are the same as well. <img src="gr_images/icons/wink.gif" border="0">
Old Feb 20, 2002 | 06:32 PM
Nightclaw's Avatar
Here's a difference:
LT1 = siamese exhaust ports (o oo o)
LS1 = replicated exhaust ports (o o o o)
Here's a similarity:
LT1 and LS1 have the same bell housing bolt patterns
Old Feb 20, 2002 | 07:51 PM
JimmyKash's Avatar
here's the BIGGEST DIFFERENCE:
LS1= 15* valve angle
LT1= 23* valve angle
^ = makes the LS1 make more power so much easier <img src="gr_stretch.gif" border="0">
Old Feb 20, 2002 | 07:53 PM
Jason99T/A's Avatar
I can shift faster than you.
Don't forget about the clutch hydraulics. <img src="gr_grin.gif" border="0">
Old Feb 20, 2002 | 10:15 PM
MyLS1Hauls's Avatar
[quote]Originally posted by XLR8NSS:
<strong>DOH!!
I thought the bore spacing was one of the only things they did carry over from a traditional small block. <img src="images/icons/confused.gif" border="0"> </strong><hr></blockquote>
No, you're right. The center to center spacing of the bores was about the only thing carried over from the oldschool block.
Brad
Old Feb 21, 2002 | 03:16 PM
Fireball's Avatar
factory intake/exhaust runner volumes are massively different I believe.
Similarity: They both have 8 pistons <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
[ February 21, 2002: Message edited by: Fireball ]</p>
Old Feb 21, 2002 | 06:56 PM
slow's Avatar
[quote]Originally posted by Nightclaw:
<strong>Here's a difference:
LT1 and LS1 have the same bell housing bolt patterns</strong><hr></blockquote>
are you sure about the bellhousing? i had heard they're not the same. If they are cool.
for similarities, i hear that there is one bearing that is interchangable...and thats it.
Old Feb 21, 2002 | 07:06 PM
Merlin's Avatar
I know really nothing about LT1's, so this may sound dumb, but it is an honest question. Is the LT1 block the same block as the regular 5.7L that were put in ,say, the trucks of those years and such or is it a completely different casting? One more question is how does the intake on the LT1 compare to the LS1 as far as runner length, etc.?
