which head gaskets to use???
Old Feb 21, 2002 | 04:19 PM
1dirtyZ's Avatar
Default which head gaskets to use???
which head gasket should i use if i have a 6.0 block and stock 5.7 ls1 heads???? is it the 6.0 gasket? or the 5.7 gasket?
Old Feb 21, 2002 | 04:44 PM
Mike Morgan's Avatar
Default Re: which head gaskets to use???
You'll need to use a 6.0L gasket. I'd also recommend opening up the heads to match the more size too. This will prevent possible detonation or pre ignition problems.
