Need the code # for misfire and rear o2, need quick help...
Old Feb 23, 2002 | 11:28 AM
brendon's Avatar
Default Need the code # for misfire and rear o2, need quick help...
I am sending out my pcm to Ed Wright, I need to give him the code number for these codes, can you give me the numeric code that wold appear on the dash.......
random misfire
rear 02 (caused from removing the cats)
AIR system code (the code you get when you remove the AIR system)
I am also having him disable the CAGS, rev limiter to 6600, top speed limiter gone, fans set for 160 stat, adjusted idle speed for cam, air/fuel, 4.10 gears and tire size.
What else do you recomend I have him do, I have an M6 without TCS. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Old Feb 23, 2002 | 02:13 PM
brendon's Avatar
Default Re: Need the code # for misfire and rear o2, need quick help...
??? A little help
Old Feb 23, 2002 | 06:38 PM
brendon's Avatar
Nobody knows the code # for these codes?
Old Feb 23, 2002 | 07:03 PM
Palm Beach Z's Avatar
Ed Wright knows all about these codes and their numbers. Just be sure to mention them to him. Here are some of the items I had him do.
P0300 multiple misfire code
Increase timing to 30 degrees
Delete AIR ( or code P0401)
Delete EGR <img src="graemlins/gr_angel.gif" border="0" alt="[angel]" />
Old Feb 23, 2002 | 09:42 PM
brendon's Avatar
I emailed Ed Wright and he said for me to put donw the code#....?? I don't know why but he said that I couldn't just give him for example, random misfire code, he wants P0300.
Does anyone have the code # that appears with not cats?
Thanks for those codes Jerry <img src="gr_stretch.gif" border="0"> I guess I am going with the custom tuning and not LS1 edit <img src="gr_stretch.gif" border="0">
