pics of ported oil pump and correct setup on engine
Old Dec 2, 2008 | 09:46 PM
427's Avatar
427
I like to center them, but its not needed. When they go down the assembly line the pump is installed fully assembled.
You sometimes see little marks in the drive mandrel were it rubbed on the main housing, this is why I center it. Probably does not matter much, but I feel better!!
Kurt
Originally Posted by Full-Force
So taking a new oil pump and just bolting it on is a no no?
Old Dec 2, 2008 | 10:03 PM
Irocss85's Avatar
good info 427.
Old Dec 3, 2008 | 05:26 AM
vettenuts's Avatar
Originally Posted by 427
I put feeler gauges in between the main housing and the drive hub with no oil pump gears in place to center the main housing.
The other thing thats important is the chamfer on the outer ring, it must be installed first (towards the rear of the pump). If this is installed wrong the pump will try and lock-up as the gear will be bound on the cover. Most pumps have a "DOT" on the front of the outer ring, but I have noticed some of the new ones do not.
Kurt
I could understand that if the housing is rubbing (although aluminum against steel, aluminum loses), but the gears float so that I still don't follow. To me, I'd rather do a careful job of assembling the pump on the workbench and install as a unit.
Old Dec 3, 2008 | 06:19 AM
djsanchez2's Avatar
Good write-up i'll be buying a used pump and want to rebuild/port it myself.
Also is it just me or are there 2 pics missing? I see 2 sets of IMG boxes w/ a pic between them....
Old Dec 3, 2008 | 08:18 AM
427's Avatar
427
I always do what I can to keep metal out of the engine, but the factory workers do it your way and it works.
Kurt
Old Dec 3, 2008 | 09:45 PM
405HP_Z06's Avatar
Kurt
I install oil pumps the same way.
Old Dec 4, 2008 | 01:13 AM
Lawnboy's Avatar
Restricted User
what about if i am installing a new SLP pump (it is a high pressure meilling pump) with the SLP logo on it , milled and machined to fit with there double roller timming chain set.
Do i have to do all that allinging like said in this post
Old Dec 4, 2008 | 08:17 PM
Irocss85's Avatar
its highly recomended. but doesnt have to be done. sorta like degreeing in a cam. yeah you could just line up the dots and hope its all where its supposed to be. or you could do it the right way and KNOW its right. again, this is kinda splitting hairs. but to me this is just somewhere I dont want to skimp or assume.
Old Dec 10, 2008 | 05:14 PM
4SFEDSS's Avatar
Any chance you could post those pics up again on porting the inlet and outlet of the pump. The first few arent coming up in your first post. If you could that'd be aswesome, im just about to do mine.
Old Dec 10, 2008 | 11:28 PM
Irocss85's Avatar
yeah I will, but unfortunatly Im at home on vacation this week. and the pc with my pics on it is now at work. sorry but it'll have to wait till next week. and by then I might forget. Im sure you can find some other pics by searching by then though.
Old Oct 12, 2009 | 02:27 PM
blk96406's Avatar
Default pics
I know this is an old post, but does anyone have "step by step pics"???? Theyd be greatly appreciated!!!!
Old Oct 12, 2009 | 04:19 PM
  #32
ae13291's Avatar
damm this is a badass thread!
Old Nov 23, 2009 | 07:03 PM
  #33
Pavetim's Avatar
Since somebody else asked it, how do you and what do you need to do so you can install a double roller timing chain?
Old Nov 23, 2009 | 08:13 PM
  #34
BaddBird's Avatar
Step by step with pics.
http://www.andersonperformance.net/L...rting_v1.2.pdf
Old Nov 23, 2009 | 08:30 PM
  #35
ae13291's Avatar
Originally Posted by BaddBird
that is a badass write up
