LS6 springs max?
Old Jan 9, 2007 | 08:42 AM
Blackmagik's Avatar
Default LS6 springs max?
What is the max lift that a LS6 spring can take?
P/N 12565117
Old Jan 9, 2007 | 08:46 AM
brad8266's Avatar
If you are worried about it then you need upgraded springs, period.
Old Jan 9, 2007 | 08:50 AM
Blackmagik's Avatar
Well, i upgraded to the LS6 springs and was wanting to throw on some bigger lifters. But your right, i should just upgrade again and get over it...
Still, I'd like to know...
Old Jan 9, 2007 | 08:55 AM
brad8266's Avatar
Why bigger lifters when you could get longer pushrods or just get higher ratio rocker arms?
Old Jan 9, 2007 | 08:58 AM
Blackmagik's Avatar
I meant rocker arms
I have the LS1 hot cam, and LS6 spring, but i want the upgrade the ROCKER ARMS. sorry
Old Jan 9, 2007 | 09:06 AM
brad8266's Avatar
I meant rocker arms
You can get away with the LS6 ones, but it would be good if you upgraded anyway while your in there swapping out rockers.
Old Jan 9, 2007 | 09:48 AM
Blackmagik's Avatar
thanks
Old Jan 9, 2007 | 10:11 AM
PREDATOR-Z's Avatar
Why?
Hotcam has .525 lifts, you can safely run 1.80 or 1.85 with the LS6 springs.
They are rated at .580 lifts.
Old Jan 9, 2007 | 10:20 AM
brad8266's Avatar
Originally Posted by PREDATOR-Z
Why?
Guess youre right, just figured why not since youre already in there anyway.
Old Jan 9, 2007 | 10:23 AM
Hennytime's Avatar
isnt the ls6 cam itself have lazy lobes, but has somwhere around .560 lift??
PREDATOR-Z's Avatar
Because it is not necessary.
Old Jan 9, 2007 | 10:25 AM
PREDATOR-Z's Avatar
02+ LS6 cam 204/218 .551/.547 117.5
