Piston choice
Old Jan 9, 2007 | 02:18 PM
DMH Fabrication's Avatar
Default Piston choice
Which cc pistons do you all recommend for the following set up? I plan on going with a diamond piston. thanks!
Stock LS1 block - .005 over
eagle h beam rods - stock length
ls6 heads w/ stock cc chambers
ARP head / main studs
ms4 cam
150 wet shot
Old Jan 9, 2007 | 03:17 PM
brad8266's Avatar
I would consider flat top postons with valve reliefs in them and then mill your heads some and go with a small gasket, this will help to retain some DCR so you dont lose so much low end power. I cant say though how miuch you can mill though, you can get a clay test done before you do it all and it will tell you how much you can mill.
