What type of oil do you use?
Ever poured some 5w30 in your hand? Looks like colored water. Do you really trust something that thin to protect your bottom end when you're constantly spinning it up to 6000 rpm's daily??
I ran Valvoline 10w30 Synpower in all 3 of my Camaro's, and the same in my LS1. Never had a problem and my LS1 does not smoke at all.
[ March 03, 2002: Message edited by: zombiedude ]</p>
I'm by no means an oil expert, but won't 5w-30 and 10w-30 have the same thickness at operating temp? I was under the impression that 5w-30 was supposed to be thinner oil when cold for quicker circulation and easier circulation on startups.
<strong>Don't want to step on a thread but I keep hearing bout the ring thing. How can I solve this issue. What are the 'better rings to use. If u dont mind. Thanks. <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> </strong><hr></blockquote>
I pulled this off of a local F-body mailing list, not responsible for it's content. It's a TSB, and applies to 1999 & 2000 M.Y.'s, including Vettes...
99-2000 Camaro,Firebird,Corvette w/ vin G or S engine.Subject:High oil consuption may be caused by faulty piston rings .Oil consumption may be one quart in 400 to 600 miles.The problem is found more often in cars w/ manuel transmissions where the engine is more likely to spend more time at higher rpm.New piston rings from kit #88894299 should be installed,but not the whole set.Install only the number 2 compression ring .Leave the the original number 1 compression ring and the oil ring rails on the pistons.Do not dress or hone the cylinder bore.Changing the original bore finish may make the problem worse.Bulletin 01-06-01-023.
It does show up on Alldata's list under 2000 Pontiac Firebird. http://www.alldata.com/recalls/
Hope this helps
Rich
Since 3000 miles. Now at 75,000. Doesn't use a drop between changes. So yeah, I trust it completely <img src="gr_grin.gif" border="0">
For those of you running Mobile One, Is that the special Alabama blend? I thought that was only available in Alabama? <img src="gr_images/icons/wink.gif" border="0">
[ March 03, 2002: Message edited by: TTopJohn ]</p>
<strong> . . . 99-2000 Camaro,Firebird,Corvette w/ vin G or S engine.Subject:High oil consuption may be caused by faulty piston rings .Oil consumption may be one quart in 400 to 600 miles. . .
Rich</strong><hr></blockquote>
So then, if somebody's car is sucking a quart to a quart and a half every . . . oh say . . . 4 -5 thousand miles; that would be considered ok <img src="images/icons/confused.gif" border="0">
<strong>
I couldn't agree with you more. 5W30 was designed for CAFE (emissions). It can AND WILL displace from the bearings at high rpm and you can very well find yourself with spun rod bearings as a result. I looked at many of the cases of spun bearings on LS1s in the past and 5W30 was the oil in almost every one of the cases <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Though 5W30 and 10W30 have the same base, the additives that allow the cold start viscosity will thin out the base. Thus 5W30 is significantly thinner that 10W30 at operating temps.
I personally run 10W30 but will be switching to good ol' molasses oil once it warms up a bit since I'm getting up there in mileage (15W50 I think)
