Will these heads work for me???
Old Jan 10, 2007 | 06:53 PM
LSWONTA's Avatar
Default Will these heads work for me???
My friend bought these heads about a year ago from a member on here and is going a different route and i was wondering if these would work for my application or just be "too much" head for my application.I have a 98 Z28 Vert with all bolt ons and an MTI X1 230/227 .591 .571 112 LSA camshaft "crappy" stock 98 heads and 4.56 gears.Never reall got any tipe of info on the heads just what was in the post.https://ls1tech.com/forums/lsx-parts-sale/436676-stage-3-ls6-heads-1600-shipped.html
Thanks for any help.
Old Jan 10, 2007 | 06:57 PM
mr2guru's Avatar
"stage 3" heads usually indicate 2.08 valves. There is no way they will fit with the X1 without flycutting quite a bit.
Old Jan 10, 2007 | 07:01 PM
JRracing's Avatar
Most people do not lose there flow sheet for there heads. I would want solid proof of what they did on the bench and what they are. I got screwed on a set of used heads I got on this board. And for that price.... You could get some real nice NEW ones.
My .02.
Old Jan 10, 2007 | 07:08 PM
LSWONTA's Avatar
Thanks for the help guys he ended up getting them for $1000.He had them running on my old 02 z28 with an FMS F11 228/230 .576 .595 114 LSA with no flycutting.
Old Jan 11, 2007 | 05:27 PM
LSWONTA's Avatar
Would 2.08 valves really cause that much trouble to have to flycut?Im just asking because we installed them on his ride with a little bigger cam and no problems would i gain any power from these to make it worth the swap?
Old Jan 11, 2007 | 09:14 PM
mr2guru's Avatar
I had mocked up UNmilled MTI stg2e (2.02 valve) heads, stock .060 gasket, and the X1 on a 112. I clayed and had less than .040" clearance on the intake valve. Needless to say I didn't run that combo. The X1 is tight.
YMMV but whatever you do... check your clearance before you crank it up.
