Help me set this up
Comp Cam . Cartek grind – Duration at 0.50 234 244. Lift .598 .596 with a 114 lobe separation
241 6.0l heads, milled to 62cc, port and polish job. The normal head work, nothing to crazy. Flowed 320s@600]
LS6 intake, LT, Pulleys.
WHat would u degree this cam at, 0 +2+4?? Also have a new stall 3600,3:73 gears.
What would you recomand on install of the cam, also people talk about different lobes, what is this cam and what is the differance? how much hp you think this setup would put down with good tune unlocked vert.
thanks
thanks
