WANTED: 2001 LS1 Specs
Old Mar 7, 2002 | 08:07 PM
Gold Phoenix's Avatar
Default WANTED: 2001 LS1 Specs
I want all available specs on the 2001 LS1 motor. Head design, intake/exhaust port size flow rate, intake runner EGR or Not & port size, cam specs, exhaust manifold, injector size, fuel pressure and control, bearing sizes, windage tray, compression leakdown rate, piston material, timing curve, and any other useful information.
Old Mar 8, 2002 | 09:36 AM
WILWAXU's Avatar
Default Re: WANTED: 2001 LS1 Specs
Sounds like you need a GM Tech manual <img src="gr_images/icons/wink.gif" border="0">
I'm sure someone will chim in with some of this info..
