oil pan gasket
Old Mar 10, 2002 | 11:33 AM
1dirtyZ's Avatar
Default oil pan gasket
i tried to remove my oil pan gasket and i found out that it has two rivets holding it in ... anyone know the proper way to remove them , and the proper way to install the new one???
Old Mar 10, 2002 | 11:36 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Default Re: oil pan gasket
You need to drill the rivets out to remove the old gasket. There is no need to reinstall the rivets on the new gasket, they are there for assembly line purposes only. <img src="gr_stretch.gif" border="0">
Old Mar 10, 2002 | 11:45 AM
John B's Avatar
Moderator
Actually I think there are 4 rivets. When you go to re-install, be sure to put a dab of sealant at the timing chain cover corners, torque properly and you're good to go!
