need help with a PR length checker
Old Jan 13, 2007 | 05:26 PM
pdd's Avatar
pdd
Default need help with a PR length checker
i put the PR checker in the PR hole. i torque the rocker to 22ftibs. i cant really get my finger in there to turn the PR length checker. when i can reach it with my fingers the whole thing turns. any tips/tricks??? thanks pat
Old Jan 13, 2007 | 06:04 PM
02Z28's Avatar
I read somewhere about guys using a rubberband.
Old Jan 13, 2007 | 06:49 PM
vettenuts's Avatar
First, you don't need to torque to 22. Just snug the rocker, as long as it is seated. Further tightening only preloads the bolt. This will make it quicker to remove the rocker, turn the pushrod and then re-install. Do about 1/2 turn at a time until you are close.
Old Jan 14, 2007 | 10:35 AM
Irocss85's Avatar
as vettenuts said. your supposed to just snug (zero lash) the rocker bolt. anything after that is pushing the lifter valve into preload. you want to find the right length w/o the preload, then just add the desired preload . i.e. .080"- .100" is pretty typical. but differs with diff. lifters ofcourse.
Old Jan 14, 2007 | 01:23 PM
JPH's Avatar
JPH
correct. i will mark the checker with a paint marker on both sides so you can make sure the pushrod checker doesn't change lengths or spin on you, as you rotate it thru the lift cycles.
Old Jan 14, 2007 | 03:02 PM
pdd's Avatar
pdd
thanks for the tips guys, ill give it another go tomorrow. i just finished torquing down my heads. now it time to watch the PATS. GO PATS!!!
Old Jan 14, 2007 | 04:06 PM
vettenuts's Avatar
I was watching them, got nervous and left to check the forum's. My wife is so nervous she is about to Although she isn't swearing yet, so that's a good thing
