rod bearings and arp bolts
Old Jan 16, 2007 | 10:49 AM
GuitsBoy's Avatar
Originally Posted by chris-m
as a newbie what do they actually do though with your arp bolts and your rods?
thanks
They hone the big end with the new bolts installed and then install +.001 bearings.
Old Jan 16, 2007 | 12:45 PM
Pro52R's Avatar
OK..
another nebie..
could the rod bolts be insatlled while the engine was still in...Like just drop the pan and do 1 bolt at a time?
Or does the k-member,etc need to be dropped?
also...how much of a big deal is it to replace them? Just don't take many trips past 6500rpm?
Old Jan 16, 2007 | 12:49 PM
GuitsBoy's Avatar
Originally Posted by Pro52R
OK..
another nebie..
You can replace the rod bolts with the engine in the car, but you can not remove the rods to have them resized. That requires you to completely disassemble the rotating assembly.
Yes, you would have to drop the K member at least an inch or two to get the pan out.
on 1998 - 2000 motors, I wouldnt spin past 6400 or 6500. On the 2001+ motors, im comfortable taking mine past 6800, and some people go higher. But anyone who beats on the motor enough may well eventually throw a rod out the side of the block.
Old Jan 16, 2007 | 06:55 PM
chevyls1's Avatar
From: where ever i can store my car. (palos hills,il for now)
so should i just do the bearing and not the bolts or do nothing at all.
