Need help ASAP*big problem*
Old Mar 15, 2002 | 12:47 AM
Bryan Sutton's Avatar
Default Need help ASAP*big problem*
Tonight, I was coming home from work. Got on it pulling out of parking lot. Spun real bad and hit the rev limiter a couple of times. Right after that the engine started kind of like sputtering. Then 30 seconds later, you could start hearing pinging and rattling inside the motor. I shut it off immediatly and started it back up for a second to see if it would do it again. and ofcourse it did. I did notice that the car was smoking also. I think I just blew my motor. PLEASE tell me I'm wrong. What do you think it could be???
Thanks.
<small>[ March 15, 2002, 07:02 AM: Message edited by: Bryan Sutton ]</small>
Old Mar 15, 2002 | 12:55 AM
PewterZ's Avatar
Default Re: Need help ASAP*big problem*
Pushrod or Valve spring. Do you have a bigger cam in it?
Sorry to hear that man.
Old Mar 15, 2002 | 01:08 AM
No, the car has stock cam in it.
Old Mar 15, 2002 | 01:42 AM
PewterZ's Avatar
Im asumeing you have a 6 speed? Is it just a knocking noice or is **** plopping around in there?I bet its just a push rod!Or a few!
Old Mar 15, 2002 | 01:56 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Lets just hope you only bent some pushrods. That would be the cheap and easy thing to fix.
Rev limiter BAD for stock LS1. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Tony
Old Mar 15, 2002 | 08:41 AM
CHRISPY's Avatar
Did you raise your rev limiter?
Chris
Old Mar 15, 2002 | 09:12 AM
I raised the rev limiter to 6300.
Old Mar 15, 2002 | 10:03 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Blinking SES lite?
I think you might have bent pushrods, maybe some valves.
Car sound like it's camming now?
Old Mar 15, 2002 | 10:10 AM
My SES light stays on now because of LS6 intake w/o EGR. Yep car sounds like its camming now.
Will I have to do a complete rebuild or just replace whats broken?
Old Mar 15, 2002 | 10:35 AM
DenzSS's Avatar
What codes do you have besides the EGR?
Old Mar 15, 2002 | 10:58 AM
LS1Tech Co-Founder
Usually folks bend valves after a major misshift, like 2nd into 1st.
Might just have some bent pushrods.
Old Mar 16, 2002 | 12:20 AM
Dope's Avatar
Raised rev limit on a stock valvetrain and you weren't expecting this? Luckily you probably just got away with some bent pushrods, which is a very easy and cheap fix.
Dope
Old Mar 16, 2002 | 12:35 AM
WMSuperSport's Avatar
Bryan, if it is a valve or spring then you will have to probably pull the heads only. While youre there I would recommend installing stronger springs and pushrods.
Old Mar 17, 2002 | 01:30 PM
I don't know if anyone will believe this, but I had a mechanic check it out. He pulled the valve covers off. He said the pushrods, valve springs, and valves all looked good. He did a compression check and that was good. He put it back together and it has ran fine ever since then. I still think there is something wrong with it though.
Old Mar 17, 2002 | 04:04 PM
The Guy in MY 99TA's Avatar
I had a freind do the same exact thing... he pulled the valve covers and the number 3 cylinder pushrod(intake side) was bent into an L .... it was messed up pretty bad.... that is probably all your problem is..... not hard to change.... ENJOY..... and while your at it add some 1.8 Rockers and some hardened pushrods..... will last longer that way!!
Josh S.
Old Mar 17, 2002 | 10:47 PM
Since I think there is still something wrong with the engine, I'm going to upgrade the valvetrain and install a cam. Probably the TR-224 cam. I just wanted to know if I needed to change my lifters too. I don't want to cut any corners. If there is any chance I need to, I'm going to change them.
