What is the easiest way to drop compression???
Old Mar 17, 2002 | 10:37 AM
LJ_Z28's Avatar
Default What is the easiest way to drop compression???
I was wondering if you could change from a regular LS1 head to maybe a 6.0L head and do some work to the heads to get them to drop the compression when installed on a stock shortblock.
And if it is possible, how much compression could be dropped???
Old Mar 17, 2002 | 10:47 AM
Chris Spiess's Avatar
Default Re: What is the easiest way to drop compression???
A piston change could drop you a good margin as well.
Old Mar 17, 2002 | 02:47 PM
VINCE's Avatar
Shorty Director
Thicker head gasket..
