ARP rod bolts
Is it worth it? I'm down to the short block right now. Are these a week link or something?
I will have stock bottom end with around 11.3 compression, head & cam car.
If so don't you have to resize the bearing end of the rod?
thanx
No ther mod's required. Just remove the stockers carefully and install the ARP bolts per their instructions. (i.e. torque and loosen twice, and then final torque down).
