is this setup any good?
Old Jan 17, 2007 | 04:58 AM
onebadblackz's Avatar
Default is this setup any good?
I'm about to put a cam in my LS1... here is what i'm thinking about getting
http://texas-speed.com/shop/item.asp?itemid=174
with this cam https://texas-speed.com/shop/item.as...d=166&catid=44 with 112 lsa and a double roller timing set.. let me know if this is a good set up..... I already have a 3200rpm stall....
Old Jan 17, 2007 | 06:37 AM
ttt....
Old Jan 17, 2007 | 09:44 AM
ttt....
Old Jan 17, 2007 | 11:02 PM
ttt...
Old Jan 17, 2007 | 11:24 PM
NviouSS's Avatar
should be a good set up. i don't know if the dbl roller chain is needed though.
Old Jan 18, 2007 | 12:10 AM
BigDaddyBry's Avatar
Yeah, I'd drop the double roller for an LS2 timing chain.
Old Jan 18, 2007 | 12:18 AM
hammertime's Avatar
224 on a 112 is a great street cam, and will work well with your mild stall. I'd say get an adjustable timing set and install it +4 to boost your DCR. If you go with heads later on, you can have them milled and install the cam straight up.
Old Jan 18, 2007 | 12:34 AM
it is an adjustable timing set.... thanks guys.... I just want something that sounds mean as hell and adds power and streetable
