OIL CHANGE LIGHT
Old Mar 25, 2002 | 07:31 AM
BLK00TA's Avatar
Default OIL CHANGE LIGHT
I HAVE A 2000 TA. MY OIL LIGHT CAME ON. I CHANGED MY OIL AND ITS STILL ON. I HIT THE OIL RESET BUTTON, BUT WHEN I START MY CAR UP ITS STILL ON.I HEARD THAT THERE IS A WAY IF YOU TURN YOUR KEY FOWARD AND PUMP THE GAS OR BRAKE(NOT SURE) THEN IT WILL GO OFF. CAN SOMEONE SHED MORE LIGHT ON THIS.
Old Mar 25, 2002 | 09:16 AM
Joe99SS's Avatar
Default Re: OIL CHANGE LIGHT
All I ever do is turn the car to on (don't start it) and hold the trip reset button for 10 seconds, the light should then flash once and go off.
Old Mar 25, 2002 | 10:06 AM
XtraCajunSS's Avatar
The exact operation is detailed in the owners manual if you can't get it.
Old Mar 25, 2002 | 01:57 PM
O2BQIK's Avatar
I had this problem and was stopping by a local dealer to pick up some parts, and thought I'd mention it to them. They fixed it in about 2 seconds, but I wasn't watching so I can't tell you what they did. But, if it comes down to it, a dealer should be able to help you.
Old Mar 25, 2002 | 05:42 PM
Dope's Avatar
What I wanna know is, where is this 'oil reset' button you speak of?
Dope
Old Mar 25, 2002 | 07:05 PM
zombiedude's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Joe99SS:
<strong>All I ever do is turn the car to on (don't start it) and hold the trip reset button for 10 seconds, the light should then flash once and go off.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Mar 26, 2002 | 06:59 PM
BIG RAM 1's Avatar
I don't know if the oil reset button trick works....but sounds like it should.....I know that if you turn the key to on and pump the gas 4 times than start your car ...the light will reset.. It will come back on in 3000 miles or so...even if you change your oil before then.
Old Mar 27, 2002 | 01:25 AM
guadofreak's Avatar
YES the oil reset thing works. The "reset" button is your tripometer button. Just put the key into the "ON" position and keep the trip button pressed for at least 10 seconds and it will turn off....it WILL come on again in about 3K miles....of course my light didn't start coming on until after about 20K miles <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
