Will being untuned harm your motor?
Old Jan 18, 2007 | 02:04 PM
1999ssls1's Avatar
Default Will being untuned harm your motor?
For heads, cam, tb, maf
Old Jan 18, 2007 | 02:07 PM
Xtnct00WS6's Avatar
Just don't drive it around for too long and don't romp on it either. Your AFR will be messed up. It'll mostly depend on how far from stock you stray on both the heads and Cam.
Old Jan 18, 2007 | 02:10 PM
98Z28MASS's Avatar
as xtnct said depends on how radical a combo your building. My buddy ran around on his 224tr for a month untuned and it wasnt too bad, but if your going good sized cam with heads, maf, and ported/aftermarket tb your:
A) not going to get all the power gains you would tuned
B) could cause some serious damage to the motor if you go lean, especially in the upper rpms
My suggestion is to wait till you can get it tuned ASAP after the install
Old Jan 18, 2007 | 02:12 PM
Cobra4B's Avatar
I'm almost done w/ my G5-X2 install... I don't plan on going WOT or much over 4000 rpms until I get a chance to lock in the AFRs.
Old Jan 18, 2007 | 02:24 PM
1999ssls1's Avatar
I have had it untuned for about a month and have had at WOT a few times. I ran my lt1 car untuned for about 6 months every friday night at the drag strip.
Old Jan 18, 2007 | 03:11 PM
1999ssls1's Avatar
Anyone know from experience?
Old Jan 18, 2007 | 03:28 PM
1 Stout Z's Avatar
The mods I have in my sig have been there since 2001, have not had it tuned yet and daily drove it everyday till 2003 when I went in the military and went to japan. Have logged over 50,000 miles since installing cam and headers. Nitrous was taked off at cam header install but other than that everything is like it is in the sig. Have run around 20-30 1/4 passes and go WOT on the street a lot. Only thing I have done is drilled the throttle body blade hole out so it will idle and not die at redlights. I do know my car runs rich still so that is one safety I have without tuning. I kept telling myself I was going to get heads before I tuned but kept pushing purchasing back and back. I am going to get them in a month of so and will have it tuned as I know I am leaving a lot on the table power wise without it. But as far as hurting my motor without tuning, not here. All cars are not the same though, yours may go lean when adding different things to it as to where mine richened up(rich is safe, lean is mean). Coming from experience, don't take the chance like I have and get it tuned if you have the money from the get go. It will run better and you will get that piece of mind knowing it is right. I talked myself out of it and took the cheap way out so far it has not bitten me yet. I have been LUCKY so far.
Old Jan 18, 2007 | 03:36 PM
WhosNXT's Avatar
Get it tuned FTW
Old Jan 18, 2007 | 03:45 PM
98Z28MASS's Avatar
If you have the money for all the mods in your sig why wouldnt you spend the extra $400 to get it tuned or at least get a mail order tune? As others have posted you can get away with it for a little while but your asking for trouble.
Old Jan 18, 2007 | 08:57 PM
1999ssls1's Avatar
Most of the mods were on the car when I traded for it. The only thing I done was put a bigger cam in it.
Old Jan 18, 2007 | 10:16 PM
N4cer's Avatar
If you mod the car, get it tuned. That's all.
Old Jan 18, 2007 | 10:48 PM
Grimes's Avatar
Get it tuned
-too rich you risk washing out and damaging the cylinder walls
-too lean, and well, things like to start melting
Old Jan 19, 2007 | 07:20 AM
1999ssls1's Avatar
thanks guys
