Nitrous motor build up?
Old Apr 1, 2002 | 06:40 PM
wicked 98z's Avatar
Default Nitrous motor build up?
Can someone point me in the right direction on building a nitrous motor. I want to keep the stock crank and cid.
Im gonna shoot for 600hp at the most.
My question is what pistons should I get?
What rings?
Should I upgrade the bearings?
Should I keep the stock rods or should I upgrade them?
What else should I upgrade in the motor?
Thanks
ALbert
Old Apr 1, 2002 | 07:07 PM
RyanJ's Avatar
SSU Moderator
Default Re: Nitrous motor build up?
JE, Ross, Weisco all make decent pistons. Call and let them know what you want. (a think top ring-land is important)
Total Seal TS1 gapless rings (they make a set for the LS1).
I would upgrade rods for longevities sake. No biggie, but you will have the motor apart. Eagle, Callies, etc. all make nice rods. I would get a 6.125" rod as it will rev easier. Since you are getting custom piston, you can get the rod you want. I think the forged I-Beam rods are the hot ticket.
GM bearings are fine. I think others have used Clevite.
The oil pump can be upgraded at the time as well. Shops have they're 'ported' versions out there. basically, you just dont want any resitance in the mechanism. that makes it stick and eventually not pump up pressure. thats bad.
I believe GM now makes a metal head gasket (one PN, buy two, one for each side), but that may be limited to the 6.0L heads, since i think thats what the gasket is used for from the factory. If youre worried about popping a head gasket, this could help.
Are you also asking about heads/cam? do a search in internal engine (the search is finda fudged right now) if you can and look for cam specs or N2O cam specs. you can get some info there.
Old Apr 1, 2002 | 07:11 PM
wicked 98z's Avatar
Thanks for the info. Ive already have the Heads and cam on the car. Im just looking to have a bullit proof bottom end.
ALbert
