Any permanent damage?
Old Jan 19, 2007 | 12:23 AM
Alex L.'s Avatar
Default Any permanent damage?
Car was shaking and felt like it was on 7 cyl so I took off the valve covers and a bolt that holds the rocker arm down was halfway out. I took out the rocker and saw no damage to it. Torqued it back up and car seems to be running fine. However I notice some white smoke coming out of the tail pipes, this may go away but I was wondering if there is a chance any permanent damage could have been done. Thanks for any advice..
Old Jan 19, 2007 | 12:32 AM
heavymetals's Avatar
If it got loose enough to spitout the pushrod or clatter around then yes.
Sounds like you got lucky!
Old Jan 19, 2007 | 02:25 AM
pist0lpete's Avatar
The white smoke was probably just all the unburned fuel in that particular cylinder coming out. Also it may just you being a big paranoid(understandably so).
