Mellings pump Vs Ported Ls6
Old Jan 21, 2007 | 02:54 PM
ArcticZ28's Avatar
So who's running what for the spring options?
Old Jan 21, 2007 | 03:31 PM
miami993c297's Avatar
Low tension spring, 45 psi at 900 rpm at oil temp 220°.
Max press hot and reving.
At start-up the press goes up instantaneously, that can only save the engine...
Christian
Old Jan 27, 2007 | 11:27 PM
00BlackSS's Avatar
hmm, im really gooing to look into this pump for my set up
Old Jan 28, 2007 | 03:17 PM
JPH's Avatar
JPH
i use the blue spring in all the pumps i put on.
Old Jan 28, 2007 | 07:41 PM
ArcticZ28's Avatar
Is that the low or high tension one?
Old Jan 28, 2007 | 07:51 PM
03 BUSA's Avatar
Rule of thumb is 10psi for every 1000 rpms. For you app atleast 75 psi
Old Feb 2, 2007 | 11:02 AM
Tiger2o69's Avatar
I would want more than 10psi for 1000... Just MO. I like around 40+ at idle and mine already pegs at 80 with stock pump but im getting the melling.. Well did peg at 80 before the spun bearing.. Due to building issues not the pump..
yeah which spring is the high and low
How many psi at idle does the high put out.. Is there a disadvantage to having too much oil pressure?
Old Feb 2, 2007 | 06:41 PM
JPH's Avatar
JPH
blue=low (40psi+ at idle hot)
red=high (50psi+ at idle hot)
Old Sep 8, 2007 | 11:51 PM
Tram's Avatar
LSWon00 - but are you a controller, what do you work?
Old Sep 9, 2007 | 06:47 AM
njc.corp's Avatar
IS THE M295 pump better then ported ones- also does the m295 come with 2 spring rates or is that the m296 version only-
Thankyou-
Old Sep 9, 2007 | 10:15 AM
bad6as's Avatar
so for a cam only with maby a 125 shot on a 346ci should i go with melling, stock ls6 or a ported ls6
Old Sep 9, 2007 | 10:33 AM
  #32
Tram's Avatar
I am going with the Melling pump on my heads/cam swap.
Old Sep 11, 2007 | 10:20 PM
  #33
DCx's Avatar
DCx
i found the best price on the melling pump at scoggin dickey parts center.
http://www.sdparts.com/product/MEL10...ESSUREOIL.aspx
$88.95
*DON'T EVERYONE HAVE A COW, THEY ARE A SPONSOR*
Old Sep 11, 2007 | 10:29 PM
  #34
DSRCAM's Avatar
how did u find it on sdparts i couldnt find it all.
Old Sep 11, 2007 | 11:02 PM
  #35
DCx's Avatar
DCx
just type in:
10295
and look for it on the list. its like the 6th one down.
Old Sep 12, 2007 | 04:40 PM
  #36
bad6as's Avatar
is that the same pump that thunder has for 150?
Old Sep 12, 2007 | 05:25 PM
  #37
litle88's Avatar
i have the 10296 melling oil pump from speedinc http://www.ls1speed.com/cont.cfm?cid=C0000699
and I love it I have a hotcam and the supporting mods in my sig.
I love the instant oil pressure at start up, and at wide open throttle I am confident that the extra Volume and Pressure of oil is there. Speedinc also has free shipping for this product cause it is over 100 bux. But its my .02cents!
Whatever you do might as well upgrade since you are going in there anyways!
Goodluck
Old Sep 13, 2007 | 10:47 AM
  #38
Ericbigmac83's Avatar
They have the melling hi performance one for $130
http://www.sdparts.com/product/MEL10...MEOILPUMP.aspx
