Need Hours Estimate help for engine work
Old Apr 7, 2002 | 01:40 PM
MelloYellow's Avatar
Default Need Hours Estimate help for engine work
Hey y'all.
Having some engine work done on a crate engine with the engine OUT OF THE CAR. No labor spent removing/installing the engine yet.
Heads come off.
Old gasket cleaned off, new gasket installed.
New Pushrods installed.
New valvesprings installed.
New Cam installed.
Preload measured with Dial Indicator.
Drilling crank with jig for pins. 2 holes drilled 180* opposite. No need to drop rack & pinion.
With this work being done out of the car, how many hours of labor for an experienced LS1 mechanic would be fair?
Thx!
<small>[ April 07, 2002, 01:42 PM: Message edited by: MelloYellow ]</small>
Old Apr 7, 2002 | 01:41 PM
Terry Burger's Avatar
Default Re: Need Hours Estimate help for engine work
Maybe 2.5hrs? Just do it yourself that stuff is all easy once the engine is out.
Old Apr 7, 2002 | 01:49 PM
Thx. I may have edited and added a few things after your reply. Sounds pretty low on hours. Everyone else agree?
Thanks
Old Apr 7, 2002 | 05:34 PM
99 WS6's Avatar
I think 4 hours would be about right. But a lot of that stuff is pretty simple and you might want to give it a try yourself. Changing valvesprings is really easy with the heads removed.
Old Apr 7, 2002 | 09:28 PM
Thx. If I had a garage and tools I'd take a shot at some of it. I do give a hand a get to watch and learn.
Also need to swap gears & timing chain after the cam goes in. 4 hours sounds about right.
Thanks!
