Anyone ever picked up power with !pcv?
I can see changing crankcase pressure being more prone to hurt performace, but not show many gains..
Josh
You will increase HP if you can increase scavenging from the crankcase without sucking out all the oil in the process <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Good crankcase scavenging reduces oil roping and creates a vacuum in crankcase area.
Smokey Y did a lot of work in this area I believe.
A dry sump for our cars would be killer and probably give us a ton of HP and rpm capability.
Cheers,
Chris
