Decent cam specs?
Old Apr 14, 2002 | 09:45 AM
2kredCSS's Avatar
Default Decent cam specs?
I am buying this cam and was just wondering if it was good for a daily driver and if it would produce a decent amount of power? I plan on doing heads in the future but no time soon. Also will I need reprogramming with this cam?
Specs:
Duration at 006: 271
Duration at 050: 218
LSA: 114
Intake Center Line: 112 (2 degrees of advance)
Lift: 563
Comp Lobe ID# 3712
TIA
<small>[ April 14, 2002, 09:46 AM: Message edited by: Jim P. ]</small>
Old Apr 14, 2002 | 05:02 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Decent cam specs?
That cam will be excellent for a daily driver. One other cam you might consider is Thunder Racing's 220 cam. Both cams should make some great power, and you MIGHT hear a slight lope at idle. If I was looking for a daily driver cam for my car, I'd most likely go with TR's 220. It will still idle very well, and every little bit helps out for power. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I know that Thunder has made 402 RWHP with the Comp 216/220 and a set of stage I heads on an M6 car. That's pretty awesome for such a docile cam! I only mention it to give you an idea as to what you might expect with all of the bolt-ons and a set of heads.
__________________
