Those withe ARE heads
Old Apr 17, 2002 | 09:52 PM
ToplessZ's Avatar
Default Those withe ARE heads
I'm buying some used ARE S2 heads. I've seen in another post something about the springs hitting the valve covers? Is there something that needs to be done to the stock valve covers to remedy this. Thanks.
Old Apr 17, 2002 | 10:56 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: Those withe ARE heads
98 valvecovers need to be clearanced for dual springs. Rocker arms also need to be modified for some springs.
Old Apr 18, 2002 | 10:22 PM
ToplessZ's Avatar
The valve cover bolt hole goes into the intake port (hole in port). Tell me this isn't a serious problem. Also how can I tell if these are genuine ARE S2 heads.
Old Apr 18, 2002 | 11:27 PM
Bugblndr's Avatar
What size valves are in the heads?
Old Apr 18, 2002 | 11:49 PM
ToplessZ's Avatar
Going to take them to a shop tomorrow to measure the valves. Is this the only way to tell? I thought maybe ARE would put some sort of stamp on them or something.
<small>[ April 18, 2002, 11:51 PM: Message edited by: ToplessZ ]</small>
Old Apr 18, 2002 | 11:53 PM
AzzHauler's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ToplessZ:
<strong>The valve cover bolt hole goes into the intake port (hole in port). Tell me this isn't a serious problem. Also how can I tell if these are genuine ARE S2 heads.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are you sure it's the valvecover bolt? I think a lot of ported heads have a rocker arm bolt that comes through a little on the intake port.
Old Apr 19, 2002 | 12:06 AM
ToplessZ's Avatar
It's one of the 4 valve cover bolts that run down the center of the head.
<small>[ April 19, 2002, 01:00 AM: Message edited by: ToplessZ ]</small>
Old Apr 19, 2002 | 10:16 PM
David Lejune's Avatar
Where did you take them to get them checked out? I live in IA and need to do the same thing.
Did they flow bench them? How much do they charge.
David
 Michael S. Palmer
Old Apr 20, 2002 | 07:35 PM
Postal's Avatar
When ARE sells his heads he sends you a flow chart with your heads and your name on the form as well i believe. Might be a way of telling if this guy bought the heads or not.
Old Apr 21, 2002 | 11:38 AM
MIGHTYMOUSE's Avatar
i didnt get a flow sheet with my s2 heads
if you have centerbolt valvecovers then the heads are not 98 correct? must be 99+ so there SHOULD be no rocker clearance issue.
cut a bit off of this portruding bolt and put a dab of silicone on the end of it before you install it.
