Cammed, now for engine safety?
Old Jan 24, 2007 | 10:17 AM
pHEnomIC's Avatar
Default Cammed, now for engine safety?
Well i got my car cammed and its running great. Now i would like to preserve the engine so i can concentrate on life and building up the rest of the driveline. would hate to have to drop a few grand just cuz the engine fails on me.
It is a 40k ls1. Nno premature wear on anything that I could tell from dissassembly. I do a good job changing the oil every 3000 miles. As extra safety. With my cam, i used prc duals, chromoly pushrods, ls2 timing chain, ls6 oil pump, new spark plugs. I also tuned the car with hptuners and a wideband (needs a slight bit more idle tuning but it runs great.) I have very good oil pressure and i wait for the car to warm up before running it hard. ( have oil temp gauge that i watch). I don't have a problem with missing gears and i have my rev limiter set at 6600 (I think i should be good till 6800 but im bein a bit conservative here).
Anything else i should do to make sure i dont throw a rod, spin a bearing, or kill something else?
Old Jan 24, 2007 | 10:28 AM
brad8266's Avatar
Replace your rod bolts.
Old Jan 24, 2007 | 11:14 AM
99blancoSS's Avatar
Dont drive it hard. There are no guarantees when you start modding. My SB lost a cylinder at 81k miles. Cam only at 60k had heads for 12k. I drove it hard.
Old Jan 24, 2007 | 11:18 AM
HAMRHEAD's Avatar
Drive it and hope for the best. You seem to do everything you need to so just hope it is enough. Some engines last quite awhile.
BES Stroked Nova's Avatar
i agree with him, and changing the oil more often wont hurt... the harder you run it, more often you should change it.
Old Jan 24, 2007 | 07:04 PM
Cop Car's Avatar
a 2002 has pretty stong rod bolts and will have 0 problems spinning to 7k.
if you want to preserve your motor.. have a professional tune it, that would be the biggest thing to kill an engine
Old Jan 24, 2007 | 07:29 PM
ls1muscle's Avatar
Originally Posted by 99blancoSS
Dont drive it hard.
LOL
Run 6 qts of oil. Check your oil level frequently, especially if it burns any.
Old Jan 24, 2007 | 07:39 PM
'Trust''s Avatar
Old Jan 24, 2007 | 07:52 PM
stealth71's Avatar
No need 2002 has the good rod bolts.
Old Jan 24, 2007 | 08:16 PM
99blancoSS's Avatar
Theres a dude that just posted up about a crate engine who has 225k on his stock engine so they can last a long time and be fine. I ran with a safe tune but hammered it when ever I could.
