Head & cam install, do I have everything?
Old Apr 18, 2002 | 07:35 PM
Black Sunshine/ 00SS's Avatar
Default Head & cam install, do I have everything?
If the bolts & gaskets come tomorrow, I plan to get busy. (Thanks to Thunder!)
I will have all bolts & gaskets, antifreeze, Head, Cam, (springs pre installed.) I will have brake cleaner (to clean off pistons & gasket surface).
I know I need tq wrench, are there any other special tools I will need? Am I missing anything else? Going to John site to read up a little, Please feel free to chime in on anything I might have overlooked. Loctite? What kind?
Old Apr 18, 2002 | 07:54 PM
LS1derfull's Avatar
Default Re: Head & cam install, do I have everything?
What type of head bolts are you using? If they are non torque to yield what torque figures do they use? New razors are a good way to clean gasket off block, if you are careful.Use a vacuum to keep debris out of bolt holes and motor as you scrape block deck surface, use some type of break in lube on valve tips and pushrod ends.
Old Apr 19, 2002 | 08:06 AM
Thanks. I guess no one else here does their own head & cam. I forgot to mention to tap out each hole.
Old Apr 19, 2002 | 08:34 AM
AgaveCorvette's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong>
I know I need tq wrench, are there any other special tools I will need? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes! Crow's foot harmonic balancer puller! And an impact gun sure helps on the manifold to ypipe bolts!
Old Apr 19, 2002 | 10:08 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
<strong>Thanks. I guess no one else here does their own head & cam. I forgot to mention to tap out each hole.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think you need to be a little more patient, some of us also eat and sleep. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The 10 and 15 mm socket is your best friend during heads/cam swaps. I think the AC lines are 13mm.
I found that a ratchet wrench (correct name) was very handy for removing the power steering off the driver's head.
You must remove the coolant from the bolt holes. I have seen two LS1 blocks with cracks in them from hydraulicing.
A protractor makes for a nice DIY'er angle meter.
You'll be leaning on the fenders alot,perhaps some fender covers?
Old Apr 19, 2002 | 10:40 AM
Big Gulp Johnson's Avatar
Just did one last week...I used Blue Loctite. I hear the red is a bit stronger, but I'm sure both will do the job. Good luck with the crank pulley. Probably the most frustrating out of everything. We ended up welding two of the old bolts together...used it to pull the new one on. Might already have this, but the Hanes manual came in very handy for various torque specs. New spark plugs, oil, oil filter, assembly lube. Other than that, sounds like you're good to go. Good luck!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 20, 2002 | 12:05 AM
wizkid's Avatar
Install Director
I used E.O.S. from the Gm dealership. It is a super sticky thick oil engine lube. Cost under $5 I think too. That is what I poured on my cam, lifters, in oil my new ARE oil pump, etc.
Make sure your sockets are 6 point and not 12 pointers. you don't want to round any bolt heads off.
Eric
