So what is the final verdict on the NEW PCV valve?
TIA for the input
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by thefritz1:
<strong>Hey all curious if we've decided any negative side effects from running the revised PCV valve from GM. I was running Steve's inline filter mod but I don't want the hastle of changing the filters and I was getting no suction from the fresh air hose. Does anyone "KNOW" if using the new valve will cause any damage? I'm about to switch over to RP oil so I think i'll try the stock PCV valve for 3K and then the pin holed revised one for 3K and see if it makes a difference.
TIA for the input</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Pep Boys has an air filter for filtering the PCV line. The filter is a small acrylic bottle, filter and separator used in an air compressor-line for spray painting. It cost $19.95 and is a Camel 56-100 (a/k/a AMFLO 3000 RET) without the automatic drain, so it has a small manual drain at the bottom of the clear polycarbonate bottle. It is designed to filter solids AND liquids from air, so it should work better than fuel filters designed to separate solids from fuel.
The actual filtration is through a tiny 3/4" tall replaceable poly-spun filter and the polycarbonate container is about 3" tall and 1 and 1/2" in diameter. The oil and aerosols separate into the bottom.
I also bought 2 brass 1/4" fittings that are made by Camel and sold alongside the filter, and a brass 1/4" splicing fitting, and some screw clamps. The Camel filter with auto drain has the same part # (?!?) and I doubt if this would work in the PCV system, (which is a vacuum system and not pressurized like an air compressor) so be sure you buy one with the black plastic screw and thread lines that show through at the bottom.
When full, the polycarbonate container will hold maybe 2-3 ounces of oil. I temporarily mounted it with cable ties to the A/C condenser so I could see it and drain it. I used an extra 30" of 3/8" gas line tubing, spliced into the existing line, which I twisted 180 degrees over to reach toward the new filter.
I was interested in the filtering the PCV line after reading Steve Hovis’ well-illustrated website about PCV filters. Oil has no octane rating and collects in the throttle bore. Steve, thanks very much for the concept. It should result in a slight increase in octane for anyone though, and it is super-easy to do, in about 1/2 hour, for about $30.00 total.
This mod accomplishes more than a new PCV valve because it is an actual filter, and does not cause a reduction in air flow, which I suspect is all that the new GM PCV valve does.
I thought others would like to try it out.
A month ago I found the better-quality metal-bowl filter, and I haven't bought it yet. The Camel polycarbonate bowl is rated only to 120 degrees so I am going to buy the more expensive metal bowl aerosol-separator soon from this link: http://www.airhosereels.com/1136-8.html
Paul
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TomBusby:
<strong>Here is a variation on Steve's concept. Also, if the filter is not passing enough vacuum you can tell from a slight dip in oil pressure.
A month ago I found the better-quality metal-bowl filter, and I haven't bought it yet. The Camel polycarbonate bowl is rated only to 120 degrees so I am going to buy the more expensive metal bowl aerosol-separator soon from this link: http://www.airhosereels.com/1136-8.html</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
http://shop.store.yahoo.com/alamohose/1136-8.html
I think they are in San Antonio Texas as many "Alamo" stores are there.
However, I am not sure if the metal bowl kind will work right because the website data from this link says that it (the $60 filter) has a .9 micron filter, which is too restrictive. The $20 filter, which is the kind I am using, from Pep Boys says it has a 50 micron filter. The Pep Boys filter seems to work fine so I have not bought the other filter because I am not sure if it correct for our application, as explained in the following paragraph.
The "trick" in filter-rating terminology is that a "nominal" rating means the size in microns of the average particle that will be trapped, but the "absolute" rating means the size in microns of the largest particle that will absolutely (always) be trapped. The filters at issue are like mazes with a dead-zone of air swirl to collect drops of liquid, rather than being like a paper screen as the fuel filters are, so it is perhaps possible that the same oil-from-air filter could have an absolute rating of .9 microns AND a nominal rating of 50 microns. I suspect that .9 is an absolute rating because that is a very very tiny particle for it to be a nominal rating.
So, if someone finds out about the nominal rating of the $60 filter please post it here.
The oil on de-accel could indicate valve guide problems but it is probably the pcv, because there are so many complaints about the pcv and becasue the vacuum in the intake manifold (but also during de-accel at the intake cycle in the cylinders) is much much higher on de-accel than at other time.
For $30 total and about an hour of your time you could try the mod I suggested. I spent more time wandering around Pep Boys reading labels on all the different kinds of filters than installing the filter in my car. Look in the "painting" section of your auto parts store for this filter.
My posts are always long by comparison.
I disconnected the 2nd hose at the throttle body, then reached just forward of the pcv valve (the pcv valve is wrapped in rubber and sits on the passenger side of the engine in a little valley between the intake manifold and the valve cover) and I twisted the existing hose 180 degrees (just twist it with your hands). Then I added about 18" of hose (with a brass splice) installed the filter, and added about 18" of hose to reconnect at the vacuum source behind the butterfly. Is this about what you asked re pictures?
The pcv makes a vacuum inside the engine, which apparently improves the oil pressure very slightly. The amount is barely visible on our simple gauges. I let my pcv filter fill up with oil to try to see the pressure drop and I guess it is about 5 pounds different.
The pcv system was invented to keep pollution down but it had another unintended and favorable consequence, by essentially doubling engine life compared to the draft tube system you see under older engines. The draft tube sucked in a lot of road grit into the crakcase that ate up the bearings and cylinder walls. An engine used to be toast long before 100,000 miles. So the whole pcv system is very beneficial and you want it to operate essentially as intended, but make it better by filtering out most of the oil-aerosols before the vacuum pulls them into the intake manifold.
I like your idea. I've run the SMH PCV with good results and may move this direction.
1 Q.
Which style line/tubing are you using? Do I need something stronger than fuel line so it won't collapse? Is there a sharp bend in the line in the above example? Someone mentioned using Power Steering line. Should I use that instead?
Thx
Are folks saying that when you ask for a PCV valve now (even for the non-truck LS1) you are given the pinhole designed PCV valve?!? I'd like to try this before filtering everything.
Thanks!
I am happy with it like this. I don not plan to spend all the time setting up any of these filtration systems as long as this new valve works. I don't have a ton of time to waste on the PCV system anymore, IMO.
Thanks! Hard to find the manual drain version. Finally found one at AutoZone made by Campbell Hausfeld.
I grabbed a 90* fitting for the bend in case I need it. Have extra straight fittings too. Any updates? What temperatures are Fuel Filters good up to? Never had any probs with those in the past. I see this one is good to 125*. Find a source for replacement filter elements??
I installed the new pcv valve about 4k miles ago. Didn't do anything for my oil consumption problems.
