Estimate for Heads and Cam
Cam
Heads
Head gaskests
valve cover gaskets
timing chain cover gasket
Pushrods
I figure cam = $400, heads = $2000 (or more), and extra parts = $200 (or more). Even if we round up to $3000 for it all you you end up paying $2000 in labor.
Labor for heads AND cam should be $900-1400 depending on what is being done to the motor. If you swap the exhaust it will take them time to line everything up.
headset 300.00
Gasket 10.00
oil 11.00
Filter 10.00
Coolant 31.00
Cam 565.00
Translator 238.00
LABOR
R&R heads send out to be machined 1500.00
Replace cam.
Porting and polishing of heads (new
valves,retainers and springs 1800.00
install new maf translator 30.00
Run and tune air/fuel on dyno 300.00
Total cost with taxes $5,090.81
headset 300.00 *?* little high
Gasket 10.00 *GOOD*
oil 11.00 *GOOD*
Filter 10.00 *GOOD*
Coolant 31.00 *NORMAL*
Cam 565.00 *?* little high
Translator 238.00 *?* little high
LABOR
R&R heads send out to be machined 1500.00 *?*
Replace cam.
valves,retainers and springs 1800.00 *GOOD*
install new maf translator 30.00 *10 SECONDS*
Run and tune air/fuel on dyno 300.00 *GOOD*
Just MHO.
www.rapidmotorsports.com
I was very happy with the quality of the work and the prices. You won't regret it.
120 Gollob Drive
Birdsboro, PA 19508
Mike Kleman is the owner and anyone here will tell you that he does awesome work. He does all the work himself too.
As most heads and cam package end up with gaskets and associated parts being between than $2500 to $2900.
Labor for install seems to be $1000 to $1500 on average.
PARTS
headset 300.00 $185.00
Gasket 10.00 " "
oil 11.00 " "
Filter 10.00 " "
Coolant 31.00 " "
Cam 565.00 Around $400.00 on average
Translator 238.00 $168.00
LABOR
Replace cam. $800.00
valves,retainers and springs 1800.00 S1=$1,650
standard S2=$2,200
install new maf translator 30.00 N/C
Run and tune air/fuel on dyno 300.00 " "
My total would be $4,111.50 with S2 2.02 1.60 Ferreas with a WB edit session included. Wash and wax ready to pick up within 4 days of drop off. This is our standard pricing, nothing more or less
<small>[ April 22, 2002, 08:53 PM: Message edited by: JPR ]</small>
