Can I just "drop" in these valves?
Old Jan 25, 2007 | 07:42 PM
eb02z06's Avatar
Default Can I just "drop" in these valves?
I just got a set of CNC ported Patriot LS6 heads-bare. I also got a new set of stock GM valves with these heads. I bought them bare because I already had the springs. Now i'm thinking maybe I should just drop in a set of Manley SS valves in the stock diameter before I assemble them-but will these valves just drop in? The heads already have a 5 angle valve job. Thanks!
Old Jan 25, 2007 | 09:36 PM
Whistler's Avatar
Sawzall and Welder Mod
You can either have a machine shop do a valve job matching those valves to the heads, or take some valve grinding compound and lap them in. They'll probably be fine just lapping them yourself.
