Preluber install
on the 'moving topic' reply , thats sorta silly.. i know it doesnt matter at all but our intakes and throttlebodies also touch oil, so better move all those posts until we have the pcv problem fixed <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
I intend to install engine oil and trans fluid coolers and a remote oil filter. The pre-luber would most likely come after that. Good luck.
<strong>on the 'moving topic' reply , thats sorta silly.. i know it doesnt matter at all but our intakes and throttlebodies also touch oil, so better move all those posts until we have the pcv problem fixed <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's true, but they're not supposed to. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> The post could really go either way, but I only moved it because I felt he would get a better response here than he would in the midst of a bunch of catback and FIPK posts. no harm no foul <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<strong>I'm in process of installing an AccuSump to maintain pressure on turns and to prelube the engine and am using Earl's AN hose and fittings. Am running the lines from where the oil filter goes using a PermaCool remote filter adapter. The part number from Jegs is 771-195 (thanks to Todd Brandon on this board for the number). It has 3/8" NPT threads, in and out, and Earl's has adapters to both #8 or #10 AN hose. If you go this route, you'll need a remote filter. Hope this helps.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanx for the info. I'm installing an oil cooler as well. Sitting in this Houston traffic makes me feel uncomfortable watching my oil temp rise and pressure fall. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<img src="http://the3ofus.no-ip.com:85/images/2002-04-28/PSPreLube.jpg" alt="" />
<img src="http://the3ofus.no-ip.com:85/images/2002-04-28/FrntPreLube.jpg" alt="" />
Yes, it clears the hood fine.
<img src="http://the3ofus.no-ip.com:85/images/2002-04-28/HdPreLube.jpg" alt="" />
Next step is to install oil lines and then control box.
