GM Hotcam
Old Apr 24, 2002 | 03:03 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: GM Hotcam
It idles slightly worse than some other popular cams, and doesn't make as much power as them. On the positive side, it is a cheap solution.
Personally, I'd rather spend a couple hundred more and get a setup with a better cam and better springs.
Tony
Old Apr 24, 2002 | 04:33 PM
Tim 98z's Avatar
I have a Hotcam. I Like it ALOT for what i paid. $314 for the KIT! In a group purchase about 8 months ago! Idle sounds MEAN. I guess with an auto you might have issue's. My M6 works fine ildes chopy but stable!! Not the best Peaky HP cam but makes a good power for the price. And i only have a 6400 rev limit which i like to hopefully help it last longer. #'s are in sig. This is not bad concidering gears and all. Full weight car. No tricks, on nitto's w/19lbs air as always. In fact i had to Drive 2 hrs to dyno so it had to be in street mode. And i forgot my shortbelt. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 24, 2002 | 04:36 PM
Tim 98z's Avatar
If you want i can email you the Dyno chart. Its just a pic i took with the Digital camera but it works. I dont have a scanner....
Old Apr 24, 2002 | 05:00 PM
TransAm2000's Avatar
where in arkansas are you?? Are cams bad for long distance driving??
Old Apr 24, 2002 | 05:47 PM
Tim 98z's Avatar
I guess there not bad for driving. I drove to Memphis and back(2hrs 1 way). And ill be headding to Texas June 30th(6hrs 1 way) Witchitaw falls (SP?) for a Month. So i trust it you can put it that way.
I'm From 10min North of LR. I head Close to texas sometimes if i go to the track in Prescott ar.
Honestly i drive an hour and a half each way to the track, I would trust the car on a road trip with the cam anyday.
Old Apr 24, 2002 | 07:30 PM
35th SS's Avatar
have the hotcam for over 2 yrs now.idle@950rpm.makes decent power for whats it worth but theirs better ones out there.changing setup soon.e-mail if you have any question.check sig. for info. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 24, 2002 | 09:06 PM
Fulton 1's Avatar
When I installed my hotcam I did it mainly because I wasn't planning on doing much more to the car beyond mild bolt-ons (oil pump was dying on me and I figured doing the cam swap at the same time was a good idea <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ). I thought it would be a good match for stock heads and the various computer sims seemed to back it up. What's more there was a problem with the Comp 941 springs needed for higher lifts at the time and the hotcam, with its mild lift, could use the more reliable production LS6 springs. I also new that the older hotcam had worked well in the LT1/4 engines.
Since then, however, my plans have changed a bit and I am now looking at doing heads, etc., in the near future. When I do that I will also switch cams in order to take advantage of the new heads.
Nothing wrong with the hotcam, it definitely sounds great <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> and there is certainly a power improvement over stock. Some may find it a little bit troublesome for a daily driver depending on what you're willing to put up with, but you can certainly live with it. It's about what you would expect from a performance cam.
So, IMO, if you're planning on staying mostly stock other than the cam and some bolt-ons, the hotcam is probably on par with most other cams. If you want to have more future potential, though, I would suggest using one of the proven MTI, TR, or similar grinds. I also wouldn't let price be the deciding factor for cam selection. In the end you may have saved yourself $200, but if you end up doing it over again later it's really no money saved.
Just my opinions <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 24, 2002 | 09:20 PM
Tim, I live on Lake DeGray near Arkadelphia in the summer. How far is prescott from there?
Old Apr 24, 2002 | 09:52 PM
Tim 98z's Avatar
We pass by there to go to prescott. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> We get off about 3-4 exits west of there. As you go there next time look for Prescott you will see it. I know there is exits for it. You will be about an Hour from my house. Look us up on www.littlerockracingscene.com
Old Apr 25, 2002 | 12:59 AM
Default GM Hotcam
Can someone post numbers and if this is a decent cam or not. I was thinking of getting it cause I can get a really good price on it and my dealer said they would keep me under full warranty since it is a GM product. Don't post about warranty please just the cam
Old Apr 25, 2002 | 10:13 AM
gator's 99TA's Avatar
mods and times in sig (with tuning issues and leaking egr!). i was happy as i gained 50 RWHP with the headers and cam. that was very good. but i have not been able to get that once nice time slip yet. i wanted to be in the 113-114 mph area. hopefully with decent weather i will be there.
it is lopey. just open up the TB hole and my MAF housing ends (ported) seemed to help.
Old Apr 26, 2002 | 11:38 AM
TA_2001's Avatar
Hotcam is a great all around cam. Reliablity
is a big issue with me and needing something
that I could feel safe with.
hotcam+lid+catback here is the dyno
http://ls1info.com/article.php?sid=118
I added SLP lt's headers and its
351/364
I have 13,000 miles on the cam and springs
and am very happy..
idle problems go away with throttle blade to 15/64" and adding the trooper mod
.022" spacer on top of idle set screw
Old Apr 26, 2002 | 03:36 PM
Bluestreak's Avatar
My numbers are in my signature, and I believe they say everything that needs to be said about the GMPP hot cam and its performance capabilities. I'm sure that a few more horsepower could be had by swapping to a more aggressive cam, but since the lift is considerably lower, and in my opinion, less stressful on the valvetrain overall, I decided to use the hot cam. It's a very driveable cam, streetability is not reduced at all.
I just installed an LS6 intake and uploaded a Superchips program last night. My next dyno chart should be near 400-RWHP, which was my goal on stock heads. The cam is a solid choice, easier on the engine, and can make gobs of horsepower. I've had it for 9 months now, and couldn't be more pleased.
Old Apr 26, 2002 | 06:47 PM
Black Magic's Avatar
How does 397 RWHP and 403 RWTQ sound? Those were my numbers with the Hot Cam. I had an LS6 intake, MMS TB, and SLP longtubes. Stock heads. IT's not "popular", so many people don't like it, but I still think you'd be hard pressed to ever find a better cam. Htere are other good cams out there, but the Hot Cam is my all around favorite. 12.15 @ 120 is also pretty respectable. Email me if you want more details, as I don't have a chance to check this board as often as I'd like... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 28, 2002 | 12:07 AM
Fulton 1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">How does 397 RWHP and 403 RWTQ sound? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sounds pretty damn impressive to me - especially with stock heads <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Nice trap speed too.
