MMS springs? vs comp 918's?
Old Apr 24, 2002 | 05:06 PM
dan98z's Avatar
Default MMS springs? vs comp 918's?
Planning on going with an MMS 224/224 cam on 114 LSA, and MMS stage 2 heads. Tuning will be done by MMS also. Probably have shift points at 6600 and rev limiter at 68/6900 rpm. Im wondering if its better to go with the comp 918's and their ti retainers over the MMS setup. I did a search and found nothing on the MMS springs, anyone run these or have any info on them? Maybe Terry Burger has them on his 229? MMS said they have had a few failures on a couple of them, but its never from the spring collapsing. What do you guys recommend.
Thanks!
-dan
Old Apr 24, 2002 | 07:29 PM
Scalpel's Avatar
Default Re: MMS springs? vs comp 918's?
Comp 918's haven't failed yet. Go with them.
