? on Heads install
Old Jan 26, 2007 | 09:56 AM
ohsofast's Avatar
Default ? on Heads install
When you put on your heads that are fully assembled is there any kind of measurements that needs to be done to insure the valve springs are properly set.
Old Jan 26, 2007 | 10:00 AM
brad8266's Avatar
Crank the engine over by hand a few times to make sure everything is solid.
