are valve guides replaceable?
Old Apr 25, 2002 | 08:10 PM
1dirtyZ's Avatar
Default are valve guides replaceable?
i was changing the valve seals on my heads ( out of the car) and as i was prying the seal off, the vavle guide just broke off!
could the valve guides be replaced? or do i have to buy a new head???
Old Apr 27, 2002 | 07:19 AM
VAP's Avatar
VAP
Default Re: are valve guides replaceable?
The guides are cast iron and are pressed into the head , to repair your head you'll have to remove the head from the engine so as when the new guide is fitted, the valve seat & valve itself will need to be ground ( recut ) so as everything is nice & concentric once again.
"No you don't have to purchase an new head."
Don't stress it's <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> not a big job for your local engine machinist.
Hope this helps
