What is causing this noise? (Sound clip within)
The link below is to a sound file (1.3mb). The engine is cold. This is the first minute of runtime. The mic is about 2 feet below the front of the engine. As the engine warms the sound pitch changes but it is still there.
Engine sound
What do you think is making this sound?
Thanks
John
<small>[ April 28, 2002, 08:29 PM: Message edited by: JNorris ]</small>
Are my ideas sound?
<small>[ April 28, 2002, 09:16 PM: Message edited by: RacerX ]</small>
John
<small>[ April 28, 2002, 09:35 PM: Message edited by: JNorris ]</small>
<strong>Oh yes I hear it every day! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> The knock/tap is the noise I am talking about. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
The whine is the AIR pump.
John</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Let me know what you find. I would be interested in seeing what mine is as well.
<strong>Piston Slap!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So is this common? Are the pistons really too small for the bore? What kinda wear problem is this? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
I get it to. My '99 SS had it also. Now i have a 2002 WS6. My noise seems to come from the front of the motor, but around or behind the water pump. But i still get the piston slap noise in the mornings. Hope it's nothing serious.
Den
when- motor cold
sound- tat tat tat like a fingernail on a table
and it goes away when its hot.
I was thinking piston slap but the sound is so loud behind the timing chain cover/water pump I just don’t think it completely caused but piston slap.
I was also thinking injectors but I have unplugged one injector at a time with no reduction in noise. However the noise is timed with injector firing.
Can a bad oil pump or timing chain/gear make this type of sound?
Thanks
John
Unfortunately the noise does not go away after the car is warmed up, just the tone/pitch changes.
Go FasTA- Yes I do have a MTI (ASP?) pulley on the car. I removed the drive belts and cranked the car and the noise was still there but was not as bad. I will try the stock pulley.
Thanks
John
