Need some technical information for engine model
Old May 1, 2002 | 09:53 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default Need some technical information for engine model
I am trying to help Roger Ramjet put together all the technical information for the LS1/LS6. This information is to be used in Performance Trends, Engine Analyzer Pro (aero-thermal) modeling software. The allows you to model camshafts etc... and to see what effect those changes might have on an engine. Right now we are lacking some of the information to complete this model. I thought I would post some of the information we need to see if some of you might already have it on hand.
I would like internal dimensions (width, height, length on centerline) of the LS6 intake manifold, exhaust manifold, and head ports. Also, valve sizes, valve spring seat pressure, and rod length. Throttle body size and flow would be nice.
Thanks in advance for any assistance you might be able to provide.
<small>[ May 01, 2002, 09:55 AM: Message edited by: J-Rod ]</small>
Old May 2, 2002 | 10:16 AM
J-Rod's Avatar
Default Re: Need some technical information for engine model
Anyone????
