ls1rx7...good mod combo?!
Old Jan 28, 2007 | 02:29 PM
seeking7's's Avatar
Default ls1rx7...good mod combo?!
94 Touring LS1 RX7 for sale
94 Rx7 Touring LS1 T56
• Patriot stage 2 heads
• Crane cam 224/230
• Z06 intake
• Z06 Clutch Pack
• JTR full length headers
• True dual exhaust with X pipe
• Ported throttle body
• HINSON cooling system
• 3.90 Rear
• JDM toe link and track rods
• Koni Adj. (Yellow )Shocks
• Eibach Sport Springs
• Suspension Tech Sway Bars
• Brembo slotted and Cross drilled rotors front/rear
• Stainless steel lines
• Axxis Ceramic brake pads
Factory ABS
• Glass and seals removed prior to its New paint job
• Window seals replaced
• Seats and Interior redone
• 4 point roll bar
• 18 inch BBS style wheels and Yokohama 275/235 tires
• Engine work done by Next Level Performance
• Air conditioning
• Power steering
• Alpine CD
• Needs nothing
• Clean title
• 88k miles on car
Any forseeable problems?
Old Jan 28, 2007 | 02:43 PM
ebear's Avatar
as far as the motor part goes it looks good. I thought people with lighter cars like silvias and rx7s usually went with a bigger cam though. since the car is so light they dont need as much torque and getting a smaller cam just means less traction. I dont know how good the z06 clutch is on sticky tires either. I'm sure someone else will.
