C2 vs 226 cam?
TIA
ALbert
I dont have dyno results, but at the track I've run several high 117 mph passes and one 118 mph pass. These were all low 11.40 passes too with the best of an 11.40.
Onxyls1 has the c2 cam in his M6 car and has run 11.70@116. You should push around the list http://xs-fx.com/list/ls1tech_list.php
<strong>They should produce similar #'s.. The 226 should give me more power if setups are the same..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In the right set up... the bigger cam will make more power. But, this will entail running the motor harder (spinning it higher),
At what point is big... too big? the 222/222 makes good power. The 224/224 CAN make more power but it will have to run harder. The 226/226? same scenario, more RPM's, more rear gear, more converter, higher launch to stay out of the bog... etc. At what point do you say OK, "this" is big enough?
There are always trade offs....ALWAYS.
