Rod bearing question
Old May 3, 2002 | 09:00 PM
JNorris's Avatar
Moderator
Default Rod bearing question
If I have a bad rod bearing say on #1 can that be replaced without removing the engine assuming there is no additional damage to any related parts?
Thanks
John
Old May 3, 2002 | 09:21 PM
RacerX's Avatar
Default Re: Rod bearing question
I think I have a bad rod bearing too. I'm thinking that maybe I will have enough clearance by just lifting the engine off the mounts. I have already ordered a new oil pan to speed up the installation. I'm planning on installing some plumbing to the new pan to accomidate a prelube system and an oil cooler. Maybe my rod bearings will survive alot longer this time. I have mounted the prelube pump. Gonna mount the filter tommarrow. Then I can messure for the lines.
<img src="http://the3ofus.no-ip.com:85/images/2002-04-28/FrntPreLube.jpg" alt="" />
<img src="http://the3ofus.no-ip.com:85/images/2002-04-28/HdPreLube.jpg" alt="" />
<img src="http://the3ofus.no-ip.com:85/images/2002-04-28/PSPreLube.jpg" alt="" />
The pump ran around $250. I bought it back when supershops was still open.
Old May 8, 2002 | 11:29 PM
Guest
Guest
Posts: n/a
Hey JNorris I have it on #6 I have been wondering the same thing...RacerX have you done it yet?
