MTI Heads & Cam
Old Jan 29, 2007 | 09:38 PM
luis06's Avatar
Default MTI Heads & Cam
I've been lookin at some heads from MTI there stage 2E heads & the cam is G-1 duration 228 232 lift .581 .581 lope 113. I've also was lookin at the stealth-1 cam duration 220 220 lift .581 .581 lope 115. would these be a good combination as a daily driver. Right now im plannin on gettin a slp lid and a my rearend built tougher w/ 3.73 gears. Then a stall and full exhaust.
___________________________________
2002 stock trans am 2.18 60' 13.66@103.17 on street tires!
Attached Thumbnails MTI Heads & Cam-luis-s_ta2.jpg   MTI Heads & Cam-luis-s_ta.jpg
Old Jan 29, 2007 | 10:22 PM
Black Plague's Avatar
Of the two I would go stage 2E heads & the G-1 duration 228 232 lift .581 .581 lope 113 souds good.
Old Jan 30, 2007 | 07:28 AM
TXZ28LS1's Avatar
i would like to know also?
Old Jan 30, 2007 | 08:02 AM
Mac 2002 SS's Avatar
If it was me ,I would go with the stealth I or II cam . I belive that cam will suprise you with the power it could make. The numbers of the Stealth cams are great and I'm sure either one of them would be a great street/strip cams. I'm sure you can still run some strong 11-second et's with the MTI set-up and still be able to drive anywhere with the a/c on . I plan on installing a MTI Stealth 1 cam with a set of TEA 1.5 5.3 heads in the near future . Good luck
Old Jan 30, 2007 | 10:46 AM
jlrz28's Avatar
10 Second Fun Car
Cant go wrong with either cam, but I like the stealthy sound better go with Stealth II.
Old Jan 30, 2007 | 11:06 AM
PREDATOR-Z's Avatar
Yeap, properly done you can go low 11s with Stealth II
My best was 11.23 @ 120mph
Old Jan 30, 2007 | 04:27 PM
Zach@MTI's Avatar
If you want a stock like idle then you'll probably want to go with the stealth II cam and the 2E heads. If you want a more aggressive idle (lopey), a little more power and still maintain alot of the stock driveability then the G1 cam/Stage 2E setup will work a little bit better for you. It depends on what you want out of the car, you can still have good driveability with the G1 but if you are going for a sleeper setup then the Stealth II will work better for your needs. If anyone needs pricing let me know and I can get it to you right away. I have these parts in stock and ready to go!!
Thanks!!
Zach White
Motorsport Technologies, Inc
281-870-8787
By Brett Foote | 2026-06-04 05:00:17
