differences between stage 2/3 heads
Old May 9, 2002 | 10:44 AM
Outlaw02Z28's Avatar
Default differences between stage 2/3 heads
Is there a set standard as to what defines a "stage 2" vs. a "stage 3" head? I used to think it was just different valves, however, I see some manufacturers using the same size valves in their stage 3 heads, as others use in their stage 2's. I am doing a head/cam/header package on my 2002 M6 and don't know whether to go with the stage 2 or stage 3. I am keeping a stock bottom end for now and the near future, so does that make a difference in what I should choose? Will I see any additional gains with a stage 3 head since I'm keeping a stock bottom end? Thanks.
Old May 9, 2002 | 10:46 AM
Z00's Avatar
Z00
Default Re: differences between stage 2/3 heads
There is not set standard for stages on heads. The porters/manufacturers label them to fit their own needs. Some people's stage 2 are the same as other's stage 3 heads.
Old May 9, 2002 | 08:00 PM
ttt
