Quench.... Do i dare go with .030's?
Shortblock = HPE Forged Iron block 408. -8 CC dished wiseco pistons
Heads = Patriot Stage 3+ heads milled from 65 CC's down to 63 CC's
Cam = Custom ground by Thunder.. 250/255 615/619 on a 110.9 LSA
Current compression W/GM mls 6.0L Head gaskets comes out to be : 11.381:1
the squish on those gaskets is .051 though... leaving a very undesireable quench. so lets put some Cometic MLS 4.030 bore .030 thick gaskets in the equation...
Compression with .030 Cometics come out to be : 11.8205:1
Would it be worthwhile to swap them out to the cometics when i pull the heads to install the new valves?? am i going to see much better dyno results or is it pretty much negligiable?
also this is a daily driven rain/shine non weekend drag stip car. it MUST be able to run on 91 octane with no detonation problems. I can run race gas for when i wanna spray but other than that its a pump gas car.
any input would be VERY appreciated!! especially from some of your veterens that really know your stuff!!
currently with my .051's im running 31 degrees of timing and cant hit detonation... not gaining any power but the car wont detonate... we have tried and tried and it just holds strong lol
does anyone make .035's??? all i see is .030's and .040's... thats why i asked about the .030's.... if i could find some .035's id be all over them
btw, need to be MLS and or cometics.
Shane
I still think the tight quench had at least a little to do with it!
Shane
if thats the case then some .040 cometics will work SWEET.. anybody know of anybody who stocks .040 cometics??? i need this car back up and running ASAP.
11.8379 : 1 compression worst case scenario... that gives me a .030 quench as well which i think will work freaking sweet!
Looks like a stout setup you have coming there either choice, 550 easy on a Djet I would think it could make
hehe depends on if i ever upgrade my intake
i put down 480 RWHP on the local dynojet but now it seems as though i was down or at least handicapped on that cylinder... (see other threads
I had a 347 w/.030 quench and it spun a few rod bearings, yeah that was sweet
