4" bore = how many cubes?
Is the 6.0L still considered a member of the LS1 family like the LS6 is.
Also, can you use a 4.0 crank for a LS1 in the 6.0L? If you can, what would that make the total CI?
Has anyone done this, or does anyone not reccomend this for reliablity?
Thanks
matt
<strong>I have a question:
Thanks
matt</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, it is still considered part of the LS1 family. We just finished building this setup your are talking about at Thunder for a member on here (XtraCajunSS on ls1tech.com). If you bore the 6.0l block 30 thousandths (4.03" bore) and use the Luanti 4" stroke, you come out with 408-409ci. 6.0l heads would be a good choice on this motor as well, since they do flow better than a LS1 head and will keep the compression down. The only downside to this setup is the extra weight from the iron block, but add a lightweight k-member, dynobat battery, and remove a few other misc. items, you will offset a great majority of the added weight. And, you will not have to worry about dropping a sleeve like some of the re-sleeved aluminum LS1 blocks have.
The 6.0l block bolts in with no problems (except for one alternator bolt hole and a ground on the passenger side). However, this is easily fixed by drilling and tapping a new hole for the alt. and just grounding the wire to the motor mount.
Jason
409 is the magic number for me.
I have the crank and pistons from lunati (for the 382 stroker kit)
If these pistons will work, please e-mail me how much labor will be to bore my iron block, install the internals, and balance the motor.
I want a mid size stroker that will handle 150-200 shot of N2O, and I'm looking for a compression ration close to stock so I can run 93 octane all day long!
Probably need a good split duration TR cam to go along with it.
Matt_Brown@mail.utexas.edu.
Thank you Jason
matt
<small>[ May 13, 2002, 04:05 AM: Message edited by: Tx Phi Psi ]</small>
<small>[ May 13, 2002, 12:54 PM: Message edited by: NoMoreTA ]</small>
For a quote, give Thunder Racing an email.
Josh S.
