Oil Change
I had a synthetic blend of 10w30 put in the car with a new filter. After the oil change, the oil light comes on when I first start the car and goes off when the car is about half-way warmed up. I've read some other threads on LS1tech which indicate I need to use my oil reset button to clear this, which is fine. I can handle that.
The bigger concern is that there is also a noise I don't remember hearing before. It could be a very faint bit of piston slap. I can only hear it at idle and the frequency seems to follow the RPM until about 2k when it shuts up. The noise seems to fade out and stop about the same time the oil change light goes out during the warm-up period.
I guess my first question is this: Is the oil light triggered by the actual condition of the oil? As in, the ammount of particulate matter or the electrical resistance or something? Is the fact that it's coming on when the car is cold then going out indicative of the inside of the engine still having ickiness in it from the old oil? If so, does that mean I should do a change in about 1500 miles just to help it clean up?
The second and more pressing question: Could this noise that I'm now hearing be the result of a poor oil choice? Could it be coincidence? If it's a symptom of a poor oil choice, will it hurt anything if I let it go until the next oil change before I take care of it or should I change the oil sooner because of it?
hehe... hope that wasn't too rambling.
Thoughts?
Paul
I just wanted to make sure that I wasn't setting myself up for something catostrophic by ignoring it.
