Could my pushrods be too long?
Old May 13, 2002 | 09:38 PM
phenyxTA's Avatar
Default Could my pushrods be too long?
I just got the car back together after having the heads milled .012" and installing a set of Crane lifters. (which I think are the same as the Comp R's) I've also got the T1 cam from MTI. When I first started it up everything sounded fine. Noisy as hell since the springs were kinda dry. I ran it for about 2 minutes and shut it off to change the oil. When I fired it back up there was a loud knock coming from what sounded like #1 cylinder. My guess is that once the new lifters started to pump up it is starting to push the valves far enough to where it's starting to nip the piston. I pulled all the rockers and checked the pushrods and noticed that when I was torquing the rockers back down it was pushing the valve open slightly on all the cylinders. Any ideas?
Old May 13, 2002 | 11:01 PM
MyLS1Hauls's Avatar
Default Re: Could my pushrods be too long?
The pistons are not hitting the valves with a T1 if it was installed correctly. You never stated what length PRs you are using. If they are 7.400 you should be ok. .012" is not much off the heads. You could have a lifter problem though. They do take a little time to get filled with oil, so run it a little while longer. I've heard of bad Comp "R" lifters right out of the box.
Brad
Old May 14, 2002 | 04:40 PM
phenyxTA's Avatar
Thanks. I've had the T1 for a long time now so it's not that. I'm also using the stock pushrods. I'm going to run a compression test to make sure all the valves are seating right. I'm also going to try spinning the motor manually to see if I hear anything.
Old May 15, 2002 | 06:00 PM
heavyhttr's Avatar
Yes your pushrods can be too long! I had the same thing happen about a year ago on a customers car. Comp cams ground the wrong size base circle on the cam and wa la 3 bent valves from incorrect pushrod length with the abnormal base circle
